Daylight headlight HID retrofit question?
#46
I am so tempted to post my entire communication with these guys.... Funny yet infuriating in a way because they don't know their product at all. OR they know it but wont directly say the daylights don't work unless rewired.
#47
-Joe
#49
Had to repair some stuff with the RX this week so I could not get to the headlights. But I must say the cut off is starting ot annoy me. Not the right side extra but the left side. It's such a sharp cut off that in dark roads it's very dark at that spot. I wanna get those daylight bulbs running and see how that goes in terms of night time driving improvements..
OH! and I tried to adjust the light height and they pretty much went no where. I think the mechanism is there for looks lol.
#50
-Joe
#54
Ok got sick of it and spent about 15min turning the screws on each side till I saw results. Got about 6"+ on both sides
I will let you guys know if it's helpful. I am going to have to mod the cut off. It's too dark on the left side. Not safe in some situations for me up in the hills.
#55
-Joe
#56
I do not know
Good question! might be able to shave the existing ones as well.
I have not had the time or energy to deal with the rewiring thing for the daylights either.
#57
depending on how the aftermarket projector was install, it may be easier to change the entire projector since you will do some measurements of the inner diameter of the projector ( within aftermarket projector ) VS OEM ones to determine if it's even feasible to change the cutoff plate.
#58
^^^^^^ I will look into that if needed thanks for that.
So far after I raised them like 6-8" lol they are so high I hardly see the cut off. Good for what I want on the road, it really gets everything and is bright enough, but it's pretty much blinding to others so I will reverse it about 2-3 inches maybe and see how that goes. I looked at a distance and yeah it's shining right in allot of faces. It's surprisingly not all that bad but still need to lower it.
#59
Ok so after some drivers in front of me actually let me pass I knew the lights were way too high. So I spent another 15min and got them to just about right. Do not see the cut off anymore (accept the right side up hill part) and I think I am for the most part just on the cusp of hitting the back seats of cars. It's pretty good now I think.
I still can't get the daylights working and have no experience with wiring lol! Will re-approach it later.
Fitment is great and over all I am happy for now. I would like however to do the retrofit with the OEM as it's better quality and just over all a better way to do it. I mean keeping the ability to have your high beams turn with you and the low beams as HID's staying on straight would be so ideal.
#60
James, I guess you saw some of the pictures of my finished retrofit. Yea retrofit works really well but we also ran into issues with factory DRL and we had to disable it and use the led strip as DRL with wires connecting to 12V power source and have to be off when car is off, it took some time to make it work because a lot of the area within engine bay that had 12V power source are constant 12V meaning even when the car is off and no key in the car, there are still juice flowing but at a lower voltage.
