my spindle is bent !
so my brother was driving my car last night and it was raining like crazy and he hit a curb broke the rim so i ended up changing the rim and bam spindle is bent
so my question is i found used from junk yards but some are from a highlander 2004-2005 would it fit? and any other ideas would be very helpful
thank you
thank you
well i ended up calling 4 different dealers in canada and michigan and they all said it wont fit ! i ended up buying the parts from the dealer because no one sells them i paid 815$ for bearing, hub and spindle lets hope i don't need anything else
If you wanted the part right away what you did would probably have been your best best. However, you did not mention what year you had and which wheel was damaged -- front or rear.
Looks like you paid top dollar. Sewell would have been one place to go using the club's discount. Next, eBay has a few listed. NAPA also carries the same. Only the latter may have been quickly available to you. The rest would have had to be shipped to you.
https://www.napaonline.com/Catalog/R...+50039+2039028
Then again, hopefully your brother is picking up the tab for the parts. So, new and OEM is better. Add a new wheel and a tire or two (if AWD you need to replace both on that axle) and that drive of his gets very expensive.
That doesnt make any sense? I thought it would be the same part.
im completly forgot to put what year is my car but its 2008 rx350 AWD
im looking at the napaonline and it shows hub assy is 469$ i got that with the bearing for 298$ CDN and the carrier for 423$ came up to 722$ plus taxes 13% came up to 815$
this whole thing is a pain in the *** but its all good i was gunna change my tires in November but it looks like im gunna do it soon because my spare tire is still new and the rest are almost done
thank you for the help,
i do have the part number for all the parts if anyone wants and i the boxes says toyota on them i thought it would say lexus -___-
