transmission stopped working
2007 RX 350 transmition stopped working at 80K miles. Is there a re Call on this? Seem too early to start having transmition problems?
While there were reported issues with the RX300 transmissions back in the day there is little data for the RX350 on this topic.
Did you keep the RX up-to-date with all its required maintenance per the Owner's Manual? With the RX350 there was no requirement to change the transmission fluid as it uses WS fluid which is supposed to be good for the life of the vehicle unless you tow. However, many here believe it should be replaced at least at 60K. Still, not should not have affected anything unless the transmission was under heavy loads. If you did everything by the book you have that working in your favor.
Did you tow with this vehicle?
Cost for the rebuild is quite expensive if that is truly the problem. Who told you it was the transmission? Would be sure to have it towed to a Lexus/Toyota shop at least for confirmation and a quote.
If a rebuild of your transmission is truly required I would be talking to Lexus Corporate about the matter. Number is in your Owner's Manual.
You can search the RX forums here for the word "transmission" for a number of threads on this topic.
What fluid did you use? Was it Toyota WS?
My wife told me she check the owner manuel while she was at Valvolene and it was whtever was in there. Could it me it need fluide? This happened on an up hill and I never checked the level on flat land. I did check it while it was on the hill with the car turned off and I did see red fluid. I forgot top check it when the car was towed to flat land...
While I was on the hill the car would engauge transmition for about 20 ft and then it would diengauge and stop. I did that four times and as I got closer to the top of the hill it would enGauge far less 10 ft or less.
Very possible the Valvoline place has used the wrong fluid. Stop trying to drive it and get it towed to a dealer as soon you can. Maybe a flush and change can save it.
Never let places outside Toyota or Lexus (or certified local shops) touch the tranny.
Get it towed to a Toyota place if warranty is expired.
Good luck. And get it towed NOW.
There is a WS compatible Valvoline transmission fluid, however, no telling if you got the right one (it is very expensive compared to the normal stuff -- that is a clue) or if you now have overfilled the system.
As I mentioned above, and as also mentioned by Carver, get this towed to the shop and have it checked. Toyota or Lexus, either will do. You may have just made a very expensive mistake.
Some believe the heat, stress, dirt, chemical breakdown and wear would indicate a change of transmission fluid at least at the 60k mark if not every 30k, others believe in magic and will run the original fluid to 100k or forever because it's magical.
