Here are pics I took. You will need to remove the panel, as the switch is held in top and bottom by two taps. I used a small flat screwdriver to release them. The light is on top. You could use the Radio Shack # 7219 replacement bulb on it for a cheap fix but it will glow yellow instead of green. The stock bulb is larger, also, but I have use the RS bulb in the past in these applications and it works fine.
How do you release the top tap? That is so hard to take to switch out of the panel
