RX330 - Headlight Condensation
I recently purchased a used 2004 RX 330. I noticed that the high beam bulb was out on the passenger side. Within a few days of purchase, a car wash and a good drive in the rain later, heavy condensation appeared inside the headlight casing. Now the low beam bulb is out as well. The low beams are the blue halogen bulbs, or so I thought. I'm now learning they are part of an HID system? I tried to simply replace the bulbs myself, but I couldn't even get inside the casing. I then started to research the problem online which is where I learned of the HId issue and how expensive it can be.
I'm not anxious to take it to a dealer and spend a fortune to have it repaired.
Are these bulbs really $160 each? Could I really be facing a replacement of the whole casing and headlight system n that side? Is a dealer my only option?
Help!
Help!
well the thing is... many of us have complained about the condensation issue. it is very common on the RX and nothing has been done about it. in order to fix the bulbs on this puppy, you will have to drop the front bumper and locate all the screws for it. Its a very tricky car to deal with. In regards to the lights cost, it all depends on whats out. if you have the bluish/ white light with autofocus, then you have the HID system. When condensation gets in that, you are either looking at replacing bulbs or even the ballast that runs the bulbs to high intensity. the bulbs are like... 90$+ for a D2S bulb. if the ballast is fried, you needa look online for a new ballast or the dealer which will charge you an arm and a leg. once you get the bulbs/ballasts, id recommend resealing the whole lght fixture on your own, maybe some silicone. good luck to you!
We had this happen too but we had it replaced under warranty. Your first priority should be either sealing or replacing that headlight, if you don't you'll be going through bulbs on a monthly basis.
Use the "Search This forum" feature with the keyword "Condensation". This has been a much discussed problem. There is some very good information within the search results.
Help!
Help!
Hi Everyone. I just got my 2005 Lexus RX330 back from the dealership. I had a lot of moisture in my headlights and was told I would have to wait until they stopped working before Lexus would do the work. They stated Lexus was trying to handle customers who had headlights out first. After my third visit for service my headlight actually exploded while they were looking at it. I got both headlights replaced for free and I was also given a rental car to drive while they where working on the vehicle. My AFS was flashing on the dash before I had the lights replaced. Now no flashing light (AFS) anymore. My automatic lights work like they did the day I purchased the vehicle. Super nice dealership and worked very hard for me. Always treated with care and honor. Jim Hudson Lexus in Columbia SC can be proud of their Service Personnel. Always get my vehicle serviced there. Car is almost 10 years old and no problems. I plan on keeping the vehicle until the wheels fall off or someone offers me stupid money for it. It drives like new and no rattles or squeaks or complaints. Super Car.
