Part numbers RX 350 2007
Hi guys
With your hep and advice I was able to replace the ignition coil on #2 cylinder myself and saved some money. The VSC and check engine lights are gone My car has 62,000 Miles and I was wondering when do I need to replace the following:
1. Spark plugs (which ones do you recommend using)
2. Water pump (part number - is it same for Toyota )
3. Timing Belt (part number)
Any recommedations on websites that have good and cheap OEM parts for lexus/Toyota ?
HOw can I find which parts are interchangeable between Toyota Highlander and the RX 350 ?
Thanks guys
Thanks guys
