Tail light bulb replacement, need help.
2008 RX 350, Noticed my left rear tail light is out, it's the one in the tail gate. I first noticed the plastic nut and figured I could take it off and the whole assembly would slide out ( that's the way GM would do it ). It didn't, so I did a search on CL, I saw somewhere that you have to take the covering off the hatch door, but no real details. My question to you, are there any secrets before I start prying and pulling?
Thanks in advance, Tim
Registered User
Cover
If you want to get into the lift tail gate section. The cover is one piece with a set of pins and clips. You just need to start on a corner and pull slowly. The first time the pins will be tight.
