MPG Display help
MPG Display help
Help------2007 RX-350, The (Avg MPG) display is working fine as we are getting 20 give or take, but whats up when you push the info button over to show the (Current MPG) display, it is all over the board up and down from 0 to 90 and everywhere in between and always changing? Any ideas?
Right out of the Owner's Manual:
(4)Instantaneous fuel consumption (“MPG” or “L/100 km”)
The instantaneous fuel consumption is calculated and displayed based on distance and fuel consumption for 2 seconds with the engine running.
The displayed value is updated every 2 seconds.
Note that an accurate figure may not be shown in the following cases.
• When the vehicle is stopped with the engine running, the display will indicate the extremely high fuel consumption.
• When the vehicle is driving down a long slope, applying the engine brake, the display will indicate the extremely low fuel consumption.
Read your Owner's Manual. It is your best friend for your RX.
What you are getting is the distance (miles) traveled per unit volume of gasoline (gallons) between the display update intervals.
On a downward slope, you can see the difference with your foot resting on the gas pedal and completely lifted off.
I have used this mode to learn how to optimize gas consumption.. and be careful and dont get obsessed by looking at the gauge and not pay attention outside.
Salim
Salim
dlamb89
15
06-07-18 09:52 PM
