Tuning
Old 12-30-11, 04:58 PM
shikbas
shikbas's Avatar
Default Tuning
What they mean by your car needs tunning
Old 12-30-11, 06:08 PM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
All I know is change needed fluids, top up the rest and replace needed filters.
If there is some thing else, let me know.
Salim
Old 12-30-11, 06:35 PM
RX330inFL
RX330inFL's Avatar
Tuning? Used to mean to replace the cap, rotor, plugs and adjust the timing. Today, no cap, no rotor and no real way to adjust the timing. So, would guess they mean to replace the plugs and filters. However, depends on your situation and how the term was used in the conversation.
In short, a generic term used by repair shops to let you know that they want to charge you for possibly unneeded services.
Old 12-30-11, 09:42 PM
thomas1
thomas1's Avatar
yep, maybe if you take in your 1961 Jaguar XKE, than it is tune to the big bucks....plugs, wires, rotor, cap, adjust the timing chain tension, adjust timing....and kicking all of your money into the grand canyon of british car heaven....
Old 12-30-11, 11:18 PM
01LEXPL
01LEXPL's Avatar
depends on your mileage. Typically, its air filter, oil change, new plugs/wires [again, mileage dependant], some go as far as cabin filter, fuel filter [mileage dependant], trans fluid change, etc.
Its all subjective as to what your mileage is. Typically, the spark plugs & wires should be change every 90-100k given their Iridium, Trans fluid every 30k, fuel filter - higher miles & $$, but oil change/air filter/cabin filter/general inspection of ball joints, and some places now do the MAF cleaning as part of a package.
Old 12-31-11, 08:34 AM
bthomas
bthomas's Avatar
+1, thomas1 said, but he forgot tweaking and calibrating carbs, spark timing, valve tappets, adjust brakes, prime shocks, and re-true wire wheels, and just tightening everything that started to work loose.
Sounds like a lot but they were fun to work on. One could do most of this on his own and some was done constantly instead of mile intervals.
sqa4life
08-30-11 12:51 PM
TechGreek
SC- 1st Gen (1992-2000)
03-08-11 06:32 AM
durtysc300
Performance & Maintenance
01-26-11 11:03 AM
Devor
12-03-10 09:05 PM
ZeekGS300
11-12-07 10:08 AM
Quick Reply: Tuning
