Driver side cupholder
#32
Registered User
Vent Cupholder
I went to a couple of auto pick a parts places this week. None of them have a second generation RX to take one from. Also I emailed a couple of guys on eBay who are parting out RX's. But so far no luck
Im going to the dealer tommorow and see what a new one costs.
#35
Hang on, I just realised something. The US cars have the vent cup holder on the left hand side for the driver. Right-hand drive cars like here in Australia, have it on the right. Assuming they are exactly the same size (as they most likely would be), it would be conceivable to assume that if I got a cup holder vent from a US car (i.e. from a wreckers yard for instance), I could have a cup holder for the passenger. The same would go for the US. If that is correct, then I don't see why anyone didn't think about this before and cut a hole in the vent (apart from being able to source the part from the wreckers).
#36
I guess the pics are old. Won't load or have been removed. Shucks! I have a 2004 RX with a broken holder. I've found a replacement and need advice on accessing the 2 screws/bolts that hold it in place. I think the lower panel has to be removed to reach these bolts. Any advice would help.
#37
Hi, I replaced mine with a good used one I got off ebay.
I broke the hell out of the old one trying even worse to figure out how to remove it but I found 2 sneaky hidden screws and they are holding it in from the bottom on an angle.
I think I removed the lower cover under the steering wheel and shined a flash light up in there to find the 2 screws(10mm) and I believe the cupholder and vent came out together as one piece.
Once out I think I carefully unclipped the vent from the cupholder and installed the new one.
Hope this helps.
Hope this helps.
#38
Hope this helps.
Hope this helps.
#39
The vent on top is held in with some clips and the cupholder on bottom is held in with 2 screws under the cupholder near the back.
Once it is removed you can carefully separate the cupholder from the vent with some very brittle/old clips.
If you buy a new cupholder you can have it in your hand to see how the screws attach to the dash and how the vent clips onto the cupholder..
Hoovey689
03-13-13 09:19 AM
