SEA FOAM how to use
Old 02-25-12, 07:44 AM
shikbas
shikbas's Avatar
Default SEA FOAM how to use
Hello,can you please tell me how to use sea foam? thanks
Old 02-25-12, 09:21 AM
jfelbab
jfelbab's Avatar
I know someone who had to replace an O2 sensor and his cat failed emission testing after using Seafoam. I'd not let this stuff anywhere near my Lexus.
Why do you want to use it?
Old 02-25-12, 10:35 AM
mandyfig
mandyfig's Avatar
Use Seafoam in your gas tank. Read the directions in the can. I have not used it other than the gas tank.
Old 02-26-12, 05:14 PM
drewcam888
drewcam888's Avatar
it isnt really necessary on newer vehicles. only add the the gas tank if you think it is necessary on your lexus. i poured sea foam straight in the intake of my old truck to clean the cyclinders.
Old 02-26-12, 05:15 PM
hypervish
hypervish's Avatar
I've used it on other cars through the brake booster line. It's safest to run it through the gas tank though.
May I ask why you want to use seafoam?
Old 02-26-12, 05:16 PM
Acer
Acer's Avatar
interesting
Old 02-27-12, 01:38 AM
willyb0b
willyb0b's Avatar
i've used it in an older car. 1/3 in the gas tank, 1/3 in the vacuum line, and 1/3 in the oil (drive 25 miles then changed the oil). i'm too paranoid to use it in my lexus
Old 02-27-12, 06:24 AM
lexus114
lexus114's Avatar
I put an ounce in every tank during the winter. Helps to off set this garbage fuel that`s out now. And add`s lubricity.
Old 02-27-12, 09:00 AM
RuninRoach
RuninRoach's Avatar
i used auto-rx...
Old 02-28-12, 06:57 AM
01LEXPL
01LEXPL's Avatar
Just do as it says, 1/3 in tank, 1/3 thru brake booster, 1/3 in engine via oil cap. Drive on it for a few miles - i did 30ish then went for an oi change.
But these cars are too new to bother with this. I did it on my ES300 once - didn't smoke as bad as some of the clips you see on youtube... had 110k on it then.
I'd leave it alone, run some injector cleaner once in a while [essentially a similar 'tool' since it cleans the injectors and burns off crud on the way out, i use Lucas on the ES & RX330 once in a while].
Here we go... a cat & O2 don't simultaneously fail after a seafoam session. Your buddy had a poorly maintained car prior to doing the seafoam treatment for having those two items go at once... Please tell me you don't actually believe a proven & tested product of over 20 years, was the culprit...
Old 02-28-12, 07:57 AM
jfelbab
jfelbab's Avatar
His car, a 99 RX300, was running fairly well but had a rough idle, he thought he would fix it with SEAFOAM. After SEAFOAM his vehicle had some maintenance lights and ran worse and failed emission testing. After the O2 sensor replacement he still couldn't pass the emissions test and found the cat needed replacement. The service manager told him all this was due to SEAFOAM. The repair cost him around $1800.
Hence the reason for my question to the OP, "Why do you want to use it?"
Old 02-28-12, 10:28 AM
01LEXPL
01LEXPL's Avatar
^ service mgr is in business to make money. Had they not said they used seafoam i'm willing to be he'd be 'stumped'. I know this business, and spend time in it... Seafoam was a scapegoat in this case.
Rough idle alone tells the story here. I have the same car with same engine as that RX - runs great.
Old 02-28-12, 10:48 AM
jfelbab
jfelbab's Avatar
Doesn't alter the fact that after using SEAFOAM his car ran worse and was throwing maintenance lights. This had nothing to do with the service manager at this point as he had not been involved yet.
I've also just did a quick scan on the internet and find it not unheard of that SEAFOM has caused O2 and cat issues for some. If you like it fine, I have no oar in this water. I don't use it and have never found a reason to consider using it.
Old 02-28-12, 08:21 PM
drewcam888
drewcam888's Avatar
i have only used it on cat converter removed/free vehicles.
Old 03-05-12, 06:28 AM
lexus114
lexus114's Avatar
It`s catalytic converter safe. But I never use more than a couple ounces at a time either.
Quick Reply: SEA FOAM how to use
