RX330/350/400h DIY's (please help nominate links!)
Old 06-19-15, 08:22 PM
  #46
5W40
5W40's Avatar
Default 2006 RX330 AWD Rear Spark Plug Replacement only w/PICs
Old 06-19-15, 08:54 PM
  #47
5W40
5W40's Avatar
Default 2006 RX330 OCV(VVT) Solenoid and Strainer preventive maintenance
Old 10-04-15, 05:26 PM
  #48
doroftei
doroftei's Avatar
2007+ Oil cooler line replacement
turbojarhe (05-09-24)
Old 10-09-15, 12:22 PM
  #49
drgerry
drgerry's Avatar
Default How to R&R the Serpentine Belt Tensioner?
My serpentine belt tensioner pully is beginning to make a lot of noise. I changed the rear idle pulley thinking that was it, but it wasn't.
Has anyone posted a DIY for tensioner remove/replace? I can't seem to find it. Please paste a link if you have one.
Thanks . . . .
Old 02-22-16, 10:15 AM
  #50
VNTR
VNTR's Avatar
A member here is looking for a thread I recommended which I can't find, if anyone can help.
It was a full thread about resetting all the features that revert to default once you switch the battery...Such as moonroof alignment, power window controls, etc.
I was hoping it would be here and think it should as it's very valuable.
Thank you in advance.
Old 08-03-16, 05:31 AM
  #51
boroda4
boroda4's Avatar
Hi everyone! I'm a new member on this forum.
Does nymody know where I can get ECU firmware for my RX330 2004? Dump of ECU is 89663-48182.
Great thanks for any help and links!
Old 09-23-16, 12:29 PM
  #52
Sevenfold
Sevenfold's Avatar
I used the DIY for the front control arm bushings! It was great! Honestly, no surprises. Very simple to follow, awesome pictures and instructions.
Damian
Old 02-28-17, 05:51 PM
  #53
lexuscb
lexuscb's Avatar
Helpful tips.
Old 04-04-17, 10:13 AM
  #54
aneidiaz
aneidiaz's Avatar
HELLO CLUB LEXUS!
Been reading thru the threads and I can't seem to find a DIY for this... Can someone point me in the right direction? OK so I was vacuuming my jeep and the fuse must've blown to the power outlets. I looked in the engine bay fuse box and seen that the fuse for POWER OUTLET NO2 still looks intact. I haven't changed it yet ima go soon to the store..... But just incase it's not that fuse responsible for both outlets.... Where is the fuse box for these outlets located??? I'm hands on. I'm just tryna determine what the exact problem is. Any help is deeply and kindly appreciated! GodBless!
Attached Thumbnails RX330/350/400h DIY's (please help nominate links!)-photo492.jpg   RX330/350/400h DIY's (please help nominate links!)-photo848.jpg   RX330/350/400h DIY's (please help nominate links!)-photo648.jpg
Old 04-30-17, 11:47 PM
  #55
5W40
5W40's Avatar
Default 2006 RX330 Liftgate Lock Actuator Repair
Dealership will sell the lock actuator assembly around $281 and $211 you can buy from online shop. a used item you can also buy from ebay if IT IS the right parts,
but a $5-$7 motor may well save the whole thing!
Both says are fit for 2004-2009 RX330 or RX350, but quite different of mine, maybe both are redesigned one?
Old 07-20-17, 04:22 PM
  #56
neelnaik
neelnaik's Avatar
Rear Marker Light Removal/Replacement DIY
https://www.clublexus.com/forums/rx-...install-2.html
Old 07-20-17, 04:35 PM
  #57
neelnaik
neelnaik's Avatar
Towing hitch/Wiring Harness Install DIY
https://www.clublexus.com/forums/rx-...tow-hitch.html
Old 07-20-17, 04:54 PM
  #58
neelnaik
neelnaik's Avatar
Replace Shifter backlight bulbs DIY
https://www.clublexus.com/forums/rx-...n-shifter.html
Old 07-13-20, 12:33 PM
  #59
iMSQ
iMSQ's Avatar
Replacing struts on RX 2nd Gen
https://www.clublexus.com/forums/rx-...l#post10476261
extra video:
Geemaan (08-10-21)
Old 11-06-21, 09:25 PM
  #60
iMSQ
iMSQ's Avatar
Lexus/Toyota Genuine Parts
The following 2 users liked this post by iMSQ:
Cherish (06-20-23), SJM (11-07-21)
Quick Reply: RX330/350/400h DIY's (please help nominate links!)
