First Aid Kit Update/Replacement
Besides cleaning the dust off the outside of the case I have barely ever touched the First Aid Kit which came with my 2004 RX330. Have never gone into it nor used any of the contents. It sits in the storage area of the driver door where the dealer put it.
Has anyone ever updated or replaced the contents of this kit? Am going to guess most of the stuff in there has gone bad by now due to heat, cold and time.
Topic I had not seen discussed previous.
Same with me, I think I looked inside mine once from my 04 ES. I would replace the band aids. Looking at mine right know, took a band aid out of the wrapper and the backing stuck to the paper. The butterfly closures a little better. Cleansing towelette still wet. Everything else should be good. I was Infantry in the Army and also instructor at Ft. Benning, had to replace a lot of first aid stuff because of the heat and humid weather.
LOTC
15
07-09-01 05:24 PM
330, aid, aide, compartment, first aid kit, have, is300, kit, kits, lexus, location, powered, replacements, rx330, vbulletin
