replacement headlights
Is there a good place to get replacement headlight housings? My headlights are still hazing after having them professionally sanded and cleaned by two different body shops. I believe they are messed up.
I have xenon bulbs if that makes any difference.
Thanks
Thanks
They weren't sealed properly if the hazing is on the outside. If they're worth the price you paid, they would have either clear coated them or used a quality ceramic sealant to ensure that it wouldn't happen again for a long time. PM me your location and I'll try to arrange something for you if I can. You definitely wont have to buy new housings if I'm right since it'll be a lot cheaper
I am looked in Ventura County California. I appreciate the help. I am going to have someone who specializes in headlight restoration to come and look at them next and see if he can fix them.
I have a question. My car key buttons don't seem to work when lately when it is cold outside. I am wondering where would purchase a replacement key transmitter . I think that is what it is called.
thanks
thanks
The transmitter is more than likely still good. All you probably need is a new battery inside the case. Go out and purchase a CR2016 battery and replace the one you have inside. Nothing else required.
I have the same hazing on the outside of my headlights. I have an '05 RX w/o AFS and I'm in Las Vegas. Is there something I can use to clean them up myself or is this a job better left to the pros? And how much should I expect to pay to have them properly treated? Thanks
