ABS and BRAKE Warning light on???
Hello there.
I have 2008 RX350 and having problem with it. Original ABS pump on my car somehow went bad. Because of that i had 3 lights(ABS, BRAKE and ENGINE) poped up and my speedometr didn't work. Lexus Dealership asked 2281+tax for new part so I bought one from used part seller for much less. The part came of from 2008 RX330 and they assured me it will work with my car. I had it installed to my car. They also Reset the computer (ecm). After isntallation Check engine light gone and Speedometr works fine. However, Brake and ABS lights are still on. I checked thread from other users but they all have VSC light on too. I don't have that. Please help
Thank You
Thank You
check for leaks. there might be a problem with the master cylinder provided your brake fluid is low despite not seeing any obvious leaks anywhere. you may need to go under the car, remove the bottom shields to inspect further.
