RX 330 A/C problem
Old 12-30-19, 05:37 PM
  #31
Nad1370
Nad1370's Avatar
Originally Posted by FLAlife
Do you know what the sensor in the dash below the steering wheel does or what it's called?
If he's talking about the A/C ROOM TEMPERATURE SENSOR, this has nothing to do with your issue.
An intermittent blinking AC light is either a failing AC compressor or AC amplifier.
If it was a wiring problem, you would have the issue all the time.
There are resistance checks on the Magnetic clutch ac compressor solenoid.
But since its intermittent, it'll be hard to catch if its bad.
Try hooking a scan tool and see if there are any DTC's for the AC.
Usually a B1451/51; Compressor Solenoid Circuit wold pop up if there is an issue with the AC compressor/Magnetic clutch.
Old 12-30-19, 05:42 PM
  #32
tomr51
tomr51's Avatar
that was sensor .
Old 05-06-20, 08:03 PM
  #33
FLAlife
FLAlife's Avatar
Just wanted to report back that on my wifes 2007 Lexus RX-350 FWD with about 95k on it. I replaced the Air Conditioning Amplifier part number 88650-0E021 pictured above and it worked like a charm. I did it in Jan 2020 so times up it works. I purchased the one pictured for about $120 on eBay. The one I got looked like a used part but was well kept unlike some others listed. Lexus wanted $900 which is a tad bit higher.
No more flashing or blinking AC Air Conditioner light RX-350 for the search engines . No more hot air and having to turn it off and on. I had the directions above and still thought I would have a professional install it. Found a highly recommended shop and it cost $40 to install.
Alls well that ends well, hope this can help out someone else.
Best of luck
Margate330 (05-07-20)
Old 07-09-21, 01:13 AM
  #34
H4L
H4L's Avatar
Originally Posted by genebolick
Had a similar experience today. Went through a large area of water and afterwards noticed that the cabin was hot, then saw that the A/C light was blinking. I'm hoping that after everything dries out it will be as good as new. If not I'm sure that I'll be back for more advice.
Thanks
I am currently have the same issue. I went through a puddle myself and ever since the ac has refused to come on. It displays on the dashboard check ac connections. It has been 6 days. don't know what to do. Please advice.
Luke15
11-20-16 11:01 AM
Qkimbrell
05-19-16 07:10 AM
BiggerOkie
RX - 1st Gen (1999-2003)
03-16-12 07:31 AM
biff44
02-14-10 10:18 PM
salimshah
02-11-07 07:01 AM
Quick Reply: RX 330 A/C problem
