Last edit by: IB Advertising
Browse all: Interior
- Why is My Key FOB Not Working?
Step by step instructions for do-it-yourself repairs
RX330 key fob not working properly
Easy and quick fix for this. You will just need to reprogram the auto feature.
First be sure you have the key turned to the ON position. Starting with the driver side window, lower it at least halfway down and then bring it back up. Holding it for about 2 seconds after it has closed. Release and test to make sure the auto is now working for that window. Now go to each door and do this to all the windows. You can than go back to the driver side door and confirm you have control of the other windows. Usually once the auto is working for the window your programming, the control on the driver side is working now too.
Now the sunroof one is a little more tricky. Using the tilt button, hold it until the sunroof opens all the way and then closes all way. I tend to hold it a little longer cause sometimes it doesnt program. Once you feel you've held it enough, check to see if the auto tilt and open/close works. Your all set.
yes the sunroof was a tricky one! thanks for your help! thanks to everybody who helped me out, i appreciate. thanks!
and for the crazy key im scared to try clean it again cause if i put the battery back in there i feel like it might go haywire again!!!!
mj23
RX - 1st Gen (1999-2003)
12-18-09 08:12 AM
