Tyres need replacing
Old 06-05-12, 10:07 PM
suraj83
suraj83's Avatar
Default Tyres need replacing
Hi guys,
i need to change my front two tyres and i was wondering what my options are.
currently i have 235/55/r18 on the original lexus rims...
i tried replacing the two front tyres with 255/55/r18, and the ride was excellent and felt well damped.
is it advisable to have two different tyre sizes on the front and the back wheels? (235/55 back, and 255/55 front?)
Old 06-06-12, 06:09 AM
DixieLex
DixieLex's Avatar
Originally Posted by suraj83
Hi guys,
IMO they need to be the same. Replace the rear tires w/the same type as front.
http://www.tirerack.com/tires/TireSe...55&diameter=18
Old 06-06-12, 06:59 AM
Carver
Carver's Avatar
It will alter the handling characteristics on unstable surfaces like rain, snow, etc. Even cornering on dry surfaces will need to be 'felt' out. Rolling diameter is the same but lateral holding forces are changed. Just take it easy until you know how it's going to handle and get matching tires for the rear when you can.
Old 06-06-12, 10:41 AM
takeshi74
takeshi74's Avatar
Not advisable but it's not the end of the world as indicated in the prior reply. It would also restrict your ability to fully rotate.
Old 06-06-12, 01:14 PM
RX330inFL
RX330inFL's Avatar
FWD or AWD?
If AWD... no, they should all be the same size.
Old 06-06-12, 03:12 PM
Zoso08RX
Zoso08RX's Avatar
No doubt, it always helps the ride quality / road noise to upsize at least one metric size.
But, you really need to do it on all four corners. Your speedo will be off a few MPH.
So figure that out before you get a speeding ticket.
Old 06-11-12, 08:36 AM
howdybob22
howdybob22's Avatar
Not the end of the world if you have two fronts that are different, but it's best to use the same brand and rotate them so they wear out about the same time. Also, it looks down right cheap (I'm pretty cheap, but I draw my line here) to drive a semi-luxury car with two different sets of tires - reminiscent of crappy vans with different brands at all four corners.
Also, you can catch sales on tirerack that are pretty reasonable. I just bought a set at $115 each + shipping for about $525 total. Had to sell them to my in-laws as I traded in my RX
alvarado3
SC- 1st Gen (1992-2000)
05-01-12 08:30 PM
RXGS
20
06-25-11 06:44 AM
akhi2003
10-27-08 08:28 PM
Quick Reply: Tyres need replacing
