cornering lamp bulb replacement rx 330
Are you referring to 194 wedge bulb as referenced in the Owner's Manual as #11, rear side marker lights?
http://drivers.lexus.com/t3Portal/do...9U/pdf/6-4.pdf
Have you bothered to search the forums? It is really easy. Even an old man like me can do it. Topics such as yours have already been discussed previous. You just need to search them out.
https://www.clublexus.com/forums/rx-...e-install.html
Lay on ground, reach up under bumper, twist lamp assembly counter-clockwise, pull out lamp, pull out bulb, insert new bulb, make sure it works before re-installing, put assembly back into housing and lock in place by turning to clockwise.
Just like any other bulbs!!!
I personally went with some red led bulbs in there!!
Search is your friend. Recommend that you type in and do a search 1st. But we have nice people around here so from time to time you get straight answers.
Thanks, Jla614
EkimAtled
12-04-18 11:11 AM
