Sorry, need answer to oil type. Thanks
Old 07-11-12, 07:52 AM
alchemist
alchemist's Avatar
Originally Posted by DixieLex
1) RedLine Oils (the very best and expensive)
2) German-made Castrol 0W-30
3) Toyota 0W-20
4) Mobil 1 0W-20 or 30
5) Castrol 0W-20
no royal purple (even though I don't use it - it has quite the cult following)?
Old 07-11-12, 12:09 PM
rcy
rcy's Avatar
3) Toyota 0W-20
5) Castrol 0W-20
1. Expensive, yes. The very best - debatable.
2. Too heavy - it's almost a 40 wieght, IIRC
Amsoil, maybe?
Old 07-12-12, 11:30 AM
takeshi74
takeshi74's Avatar
3) Toyota 0W-20
5) Castrol 0W-20
What, exactly, does this "research" consist of and what was the criteria and method used for determining "best"?
It's generally not regarded all that well. It's mostly coloring and marketing from what I understand. BTIOG's a good resource in general.
Old 07-12-12, 11:55 AM
Adamjeeps
Adamjeeps's Avatar
Any known brand of oil in the correct weight will be fine as long as you change it every 5000 - 7500 miles.
Some people say their engine runs more smoothly on some oils. It could be true, too many variables to know for sure, IMHO.
I personally like Amsoil and Ultra, but the Amsoil is more of a hassle to get, and more expensive.
Old 07-13-12, 08:07 AM
joedaddy1
joedaddy1's Avatar
3) Toyota 0W-20
5) Castrol 0W-20
Agree with RCY saying that #2 GC 0w-30 might be too thick..
it is a thick 30w and although I use it on our G35 and bmw 330.. for the lexus, it might be too thick..
won't hurt anything on the lexus, but fuel economy might suffer at bit...
Old 11-24-14, 08:53 PM
pauljcl
pauljcl's Avatar
Originally Posted by rcy
Both the 10w30 and 5w30 will be 30 weight oil (the second number) at operating temperature, so switching to 10w30 will not offer you any additional benefit despite the ambient temperature being high where you are.
Have a look at the attached chart that I received from Lexus Canada. You can run 5w30, 5w20 or 0w20 in the 2007 RX. The 20 weight might actually help the engine run cooler, believe it or not. I've attached it as picture and a .pdf so you can download a copy of the .pdf is so desired.
The chart you show seems to indicate that ALL the RXs can use the Toyota 0W20 oil.
Old 11-25-14, 04:55 AM
BensonRX
BensonRX's Avatar
3) Toyota 0W-20
5) Castrol 0W-20
It's more crowded at the top. Motul, Liqui Moly, Royal Purple are all very high quality.
Klymbort
06-05-17 02:47 PM
boss22
02-20-12 10:41 PM
GS4VIPbOSS
Performance & Maintenance
37
08-18-08 12:19 PM
ILOVEGIRLS
03-25-06 06:28 PM
RodGrp
Maintenance
04-22-01 12:21 PM
Quick Reply: Sorry, need answer to oil type. Thanks
