07 RX350 halogen to projector help please.
I just bought 07 rx350 with halogen headlights, and wanted to swap to the projectors, is it gonna work ? my has 71k miles, non- nav. 1 owner , everything serviced at lexus dealer in houston. Price was $22,000 but came down to $18,000 not including anything. Is it a good deal? Any inputs will be appreciated.
I dont think mine has AFS, its the reflector type with the yellowish output. Mine is not HID. They are regular bulbs. How to know if mine has AFS? if i dont, its not a big deal, all i need is the outside look and look ok at night when driving. I mean i want the reflector to projector type.Thanks
Is there a separate ballast to go with the HID when you go from halogen to HID? Will the existing wire support the current? I am assuming HID draws more power.
Current wiring is capable of powering the system.
HID's draw less power than a halogen bulb but put out more lumens depending on what kelvin color is chosen, typically in the 5k-8k range. Any higher they look blue or purple any lower they look yellow.
http://www.delonixradar.com.au/hid-x...lour-chart.php
Mikera
06-24-23 11:54 PM
johnpaul21
01-05-16 06:58 PM
2007, 2013, 350, flickering, halogen, headlamp, headlights, hid, lexus, projection, projector, replace, rx, rx350, white
