Rear Axle Nut Size / 04 RX330
07-31-12, 09:46 AM
Does anyone know the axle nut size for the rear of 04 RX330? Need to replace bearing/hub assembly and want to make sure I have right tools prior to tackling the job.
Thank you
07-31-12, 11:31 AM
yes you will need a 32mm deep well going to be hard to find but a 12 point will do the trick
07-31-12, 01:13 PM
Quote:
Originally Posted by
LEXRX04
Why 12 point? A 6 point is less likely to damage.
Harbor Freight carries 32mm deep well sockets if you have one in your area.
07-31-12, 02:58 PM
08-03-12, 05:45 AM
RX330inFL
a 6 point socket will not work for this
08-03-12, 07:21 AM
definetly 12 point, the nut is a 12 point...
Ken527
04-28-19 01:44 PM
Max16
IS F (2008-2014)
05-19-17 02:08 PM
soleeasii
03-30-11 09:35 PM
FiremanRX
RX - 1st Gen (1999-2003)
02-10-10 02:04 PM
07 ,
2007 ,
350 ,
axle ,
bearing ,
gs300 ,
lexus ,
nut ,
nuts ,
rear ,
rx ,
rx300 ,
rx330 ,
rx350 ,
size
