Headlight Lens
Headlight Lens
Does anyone know if you can buy the headlight lens cover seperate to the whole unit rather than buying a whole new headlight? My headlight is fairly scratched up and yellowing. I know you can get it sanded and then polished out and UV protected. I would like a new lens if it were available. This is for 04 RX330.
There is a product called plastics by maguire use it first to clean the lense if you have a buffer. Then you can use those products to remove the yellowish discoloration. Otherwise you have to buy whole thing
Try Plastx, fairly successful for me with my other yellowy lenses. I use Plastx to clean my RX' slight blemish.
There are new combo's being sold in the stores. It is a polish like Plastx and then a UV protectant that advertises to keep the lens looking clear a lot longer.
Plastx will clean your lenses but you will have to do it every couple of weeks to keep it clear. works for me.
Just remember a couple of years ago none of these products were available and we had to suffer through the yellowy dull headlamps.
