RX330 Transmission Service Interval
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Well, thank you all for the replys. I must admit that I should know better than to post anything about any oil subject on any automotive forum. I belong to many forums as I have had, and still have, a variety of vehicles. Lexus RX330, 2008 GS460, C6-Z06, 2005 SSR, 34Chevy street rod. Any oil subject brings out fanatical replys on any forum. My basic question was on the frequency of change, as the owners manual, that I have read, doesn't request you to replace the transmission fluid. To support this position, the transmission dip stick is placarded to tell you the same thing! " It is not required to replace the ATF unless this vehicle is operated under extreame conditions". I was looking for any information from individuals that had followed this advice and had adverse results. IE I followed the owners manual recomendations and under light driving conditions had a transmission failure. Old habits are indeed very hard to break, however, if you drive your vehicle 12,000 miles per year under very light conditions and you change your oil 4 times, you are surely wasting your money, regardless of what type of oil or filter you are using.
If you're the original owner and know that your RX has not been driven under severe conditions (towing a boat or a trailer, drag racing, off-roading, etc), 120,000 miles is when you should replace the tranny fluid. If you've purchased a pre-owned car, it is a good idea to evaluate the condition of the fluids, do preventative maintenance and replace as necessary for a piece of mind even at 60,000 miles.
Sorry for such a long, winded string of replies!
fj40drm
RX - 3rd Gen (2010-2015)
14
05-07-16 07:57 PM
runningox
02-20-09 12:29 PM
