Jacking Points/Jack Stand Location? 2nd Gen RX
Do you place the jack stands with the wood block under the jack point with the seam (ridge)? And if you do, did you cut out a slit in the wood block so it would fit over the seam and touch the flat areas like the hockey puck?
GiantsFan
01-12-13 12:16 AM
