initialize the electrical stuff after disconnect battery
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Hi it is weird that some equipments do not work after battery goes off for 10 mins,
things like windows, headlamp washer,
I just solve the problem for windows cuz they need to be initialized. anyone know how to initialize the headlamp washer? sometime it works but most time I press the button no response .
please help
please help
Almost every vehicle with auto up/down windows need to be reset after disconnecting the battery. The other thing you will need to reset is the sunroof, or it won't auto close properly. The instructions are in your owner's manual.
The headlights...no reset required..as already posted, they only work when the headlights are on. They will also only clean once per engine run cycle in conjunction with the windshield washer (i.e. they will spray one time, the first time you use the windshield washer for each driving cycle). After that, you need to use the manual wash button.
Coach9119
03-05-15 04:50 PM
Chris98vob
GX - 1st Gen (2003-2009)
05-27-09 08:49 AM
JOROB
05-05-08 10:22 PM
