I have a leak from the sunroof drivers side drain on floor board ?
When I apply water from hose into drivers side sunroof drain water comes shooting out of the lower kiick panel onto the floor ? I was smelling mold and carpet was wet .. pulled drivers side plastic kick panel off apply water to sunfoor drain and it pours out of a hole in the drivers side lkik panel .. ?
Not sure how this works on the lexus, but my volvo xc90 had a clogged drain. you had to take off the A pillar cover on the inside of the car and find a little rubber drain tube. usually clogged with leaves.
This topic has been discussed here before. I did a forum search with the keywords "sunroof leak" and it returned the postings below plus more:
https://www.clublexus.com/forums/rx-...roof-leak.html
https://www.clublexus.com/forums/rx-...some-help.html
https://www.clublexus.com/forums/rx-...with-leak.html
magnoman
10-21-12 03:06 PM
