Rattle Noise upon initial exceleration...
Notied a significant eeper pitched rattle upon initial excelleration or when the car was in drive and on a declined surface. Ratlle wa ony when car was in drive, and only when first accelerating or on declined surface.
After examination, I found the rattle coming from the rear engine manifold HEAT SHIELD which was rattling against the break lines, run up against the FIRE WALL area. this is not the same noise related to the heat shield underneath the bottom side of the car.
Just thought I would post in case others had the same issue or rattle upon initial acceleration.
