Rotor Discolored
Rotor Discolored
New member in need of advice,
I had a shop do a complete brake job about 3 thousand miles ago.
Now I have a discoloration on outer half of rotor. Brake feel fine, no pull, no pulsation.
Slight squeel at very low speed.
That could be the result of a loose wear clip, cheap pads, or a lack of the spacer pieces that go into the caliper assembly.
Feel the rotor (when cool) to make sure you are not grinding the rotor itself. I have also seen discoloration when usuing cheap rotors.
Not sure how familiar you are with doing a brake job, but if you disassemble the brakes then make sure all parts are properly installed, I wouldn't worry.
Thanks
Thank you,
I will go by Lexus dealer and get new brake hardware kit and replace clips.
I asked for top of the line pads and rotors, should I drop down from ceramic to semi metallic?
Thanks again.
Thanks again.
The front pads are ceramic. You should stick with that. What brand parts did you have installed previous? Independent shop or from Lexus?
Check the rotor closely and make sure it is smooth. Also inspect the caliper assembly when you have it out. I would also crease the caliper Slide BOLTS slightly to make sure they are allowing travel without sticking.
Datlore001
08-25-13 11:20 AM
