2RX Oil Line Failure - Catastrophic Consequences (pictures)
#166
Well I guess I got lucky. I found this thread and started to worry a lot. I just bought a 2007 RX350 and started doing some research on this problem. Thankfully it turns out this issue was handled. I foudn this in the service record at 47k miles back in 2010:
9LH REPLACE OIL COOLER HOSE FOR RX 350 - F
However on my recent inspection the guy said one of the boots on the suspension was damp but he couldn't see where it was coming from. I'm gonna have it checked out anyway to be safe. Ugh this is so annoying.
The 9LH Oil Cooler hose is a misnomer. It is not an oil cooler hose ...... it is the vvt-i oil line to the upper portion of the valve train and camshaft.
The oil cooler is actually on the bottom of the engine if you have the trailer tow package.
Only vehicles manufactured before April 2009 (wrong ..... see edit ..... it's April 2008) have a rubber vvt-i oil hose that needs to be replaced ..... but all 2007 to 2011 3.5L V6 Highlander (2008 forward) Sienna, Venza, and RX350 with trailer tow package have rubber hoses that need to be replaced. In Canada, they did a recall but in the USA all you get is an extended warranty.
Edit/Error: It's April 2008 NOT April 2009.
#167
Only vehicles manufactured before April 2009 have a rubber vvt-i oil hose that needs to be replaced ..... but all 2007 to 2011 3.5L V6 Highlander (2008 forward) Sienna, Venza, and RX350 with trailer tow package have rubber hoses that need to be replaced. In Canada, they did a recall but in the USA all you get is an extended warranty..
So if I don't have a tow package then I guess I have a different part instead of the rubber hose one? Im still gonna take it to have it looked at, something is still leaking from what I have heard so best to be safe.
Once again thanks for straightening out the details for me.
#168
Thanks for this...it seems there's quite a bunch of engine failure due to this leak. I checked carcomplaints.com, 90% of the engine failure complaints seem to come from this LEAK.
#169
#171
Does anyone know if this oil leak has lead to long term issues. My sister in laws 2008 RX350 dumped all of it's oil in the driveway one night. Good thing we we're running synthetic as I think it saved the engine.
BUT, the car has developed a diesel like sound at idle after it warms up.
#172
That depends on how long it was run low on oil. If the leak was fixed by a Lexus dealer under the warranty enhancement, I would take it back to them to diagnose the noise and push for coverage if it could be related.
The water pump can make rattle noises when it's failing so check that....
#173
Be careful with this, Lexus friends. My understanding is that ALL RX350s between the serial numbers you will find back in this thread aways have the rubber oil cooler lines. There was no towing package for the RX vehicles.
Some other Toyota models using the same engine had a trailer towing option, and those vehicles will/might have the rubber oil lines. Sienna, Highlander, etc.
As well, some of the early rubber hose oil cooling manifolds leaked and were replaced with the same part number, which might be the exact same poor design or perhaps something with a bit better materials. But still rubber.
If you are unsure about exactly which oil cooler lines you have, or if you have this part at all, please take your vehicle to a shop, have the plastic shrouding taken off and have this part inspected. If it's the rubber one that you can see if the pictures in the first post, have that taken off and replaced with the metal one. Let us know what you find.
Failure of this part can be catastrophic.
#174
#176
mine is 042009, and as noted, mine is metal. mine was one of the very first to hit the dealer in Washington DC area so 3rd RX should be OK. thanks for the reference.
#177
#178
Was anyone in the USA successfully able to have Lexus replace this part without any leaks present? I took my RX in for the headlight replacement recall but they said they wouldn't replace the oil line unless if there was a leak apparent. maybe i should just slice the line a half mile before getting to the dealer?
#179
