07 RX350 Windshield washer motor weird problem
Any help will be great guys. I have a friend with a 2007 RX350, he just developed a problem with his windshield washer motor. From what I understand, when he pulls on the leaver to get his glass sprayed the sound of electric motor starts and the fluid comes spraying on the windshield normaly. But after he releases the leaver the water stops spraying like expected, but the electric motor sound doesn’t go away. He basically needs to shut the car down for the sound to disappear. Not sure how is this even possible for the motor to continue to run without pumping fluid. Could it be something else? What can be triggered to run by the water spray switch?
Thank you all and a happy new year
Does anyone know what might be happening and how to fix this properly? Or I just should help him remove the light-bulb from the cluster as well.
Thanks
The headlight spray will only work when the headlights are on. When lights are on and you wash the windshield the head light spray hits the first time than not again for awhile, I'm not sure how long it waits but it won't spray the next time you wash the windshield. The headlight wash button will spray every time you push when the lights are on.
is250gurl
08-22-08 08:22 AM
