want to know should i change out the water pump when doing the timing belt , also what brand of pump and belt should i use there is a bunch of brands to use.
If you are doing this yourself the best thing to do while everything is apart is to change everything that you can. This includes timing belt, water pump, seals and accessory belts. As for brand, stay with Toyota/Lexus.
+1 stay with lexus/Toyota parts. Sewell does provide the entire kit for water bump replacement as well as a 90K service kit. I bought all the parts there and got it done at a local family mechanic place. More got done then a regular a typical 90K service but well worthfit
