Rattle under RX At Highway Speed
Maybe someone has had a similar issue. 2004 RX AWD. At highway speeds I hear a rattle from what appears to be under the vehicle. Almost like if one of the pieces of plastic which go under the engine is missing a screw. That is not the case. It sounds more like it is coming from under the driver seat area. Any suggestions would be greatly appreciated.
Thanks
Thanks
I posted a solution to this a few months ago after searching about the same noise. Long trip and the noise was under the drivers seat. The noise was driving me crazy. If you get under the car you will see a piece of plastic that is at least 3 inches away from the bottom of the car. I thought that was a lot of travel so was skeptical. I wedged a piece of styrafoam between the plastic and the body with glue on both side.
Noise gone.
I thought it was trim from roof rack flapping, had passengers reaching under the seat, etc, but the styrafoam block fixed it.
Noise gone.
Suzzetteas (12-31-22)
Does it only come on at a certain RPM. Mine had a rattle/vibration at a certain RPM and it turned out to be something loose in my catalytic converter. Thankfully Lexus replaced it as part of their goodwill.
Noise gone.
Noise gone.
I just took my 2007 RX350 in for the same reason, including the Upper Windshield "tick".
For the tick, seems they did pretty much what was outlined on the TSB L-TCI-3280 (UPPER/LOWER WINDSHIELD TICK NOISE).
The noise under the drivers seat was from some type of shield that came loose. They tightened it and I have not heard either noise.
Happy camper as frankly I was fed up with all the squeaks and rattles.
Even a 2007 with 73k miles should not have those problems.
