ATF color comparison, fresh and used at 65K miles
Old 03-31-13, 08:35 PM
dcdyd
dcdyd's Avatar
Default ATF color comparison, fresh and used at 65K miles
Here is a comparison of ATF. My 08 is at 65K and we brought it when it was 36K miles. I am not sure whether previous owner has replaced the ATF or not, most likely it was not replaced since today.
There is no burning smell. However the color is pretty dark comparing with fresh fluid. I will do another drain and fill probably when it hits 90K.
Old 04-01-13, 05:00 AM
alchemist
alchemist's Avatar
that's not too bad and about what mine looked last time i changed it. Every 30k is probably a safe bet.
Old 04-01-13, 05:38 AM
dcdyd
dcdyd's Avatar
08 RX is supposed to have 'lifetime' ATF and owner's manual says 'inspect' the liquid at 100K miles. That may be different with other cars.
Old 04-01-13, 07:12 AM
alchemist
alchemist's Avatar
Ahhh my mistake. Yeah it's similar to the GS. Can you send a sample to blackstone labs (if you have any old fluid left somewhere)?
Old 04-01-13, 07:58 AM
dcdyd
dcdyd's Avatar
I will do that and revert back.
Old 04-01-13, 08:48 AM
Rainbird
Rainbird's Avatar
Here is the Lexus Technical Service Information Buellton regarding World Standard Transmission Fluid.
File Type: pdf
Old 04-01-13, 11:06 AM
RX330inFL
RX330inFL's Avatar
Here is a key comment out of that PDF:
• ATF-WS is NOT compatible with T-IV or Dexron ATF.
RX350LB
06-21-19 09:08 AM
rizzagt22
06-16-16 05:06 PM
edg64
Maintenance
09-10-12 06:54 AM
faifai83
04-09-12 09:28 PM
bob2200
Maintenance
10-08-03 12:15 PM
Quick Reply: ATF color comparison, fresh and used at 65K miles
