Rx330 awd vs. Fwd
Okay, I have to ask........Why? Personally I really like the AWD. And I noticed it is a much more even take off from the start. Where as the fwd the front end lifts more during take off. Plus better in snow/wet handling.
Not sure if these small SUV 4wd/AWD work the same as my 4Runner but I bet it's same. Mine has Torsion 4wd on my 4Runner not AWD and has Yaw incorporated into my VSC. I know 2wd can't have the Yaw control but both All/4wd can.
With Yaw if your driving on wet/ice roads and you go over a wet/iced up overpass slick enough to make a vehicle slide around fast like black ice does, before you could react enough to actually lift your foot off your gas pedal the Yaw will have already decelerated & eccellerated whatever wheels needed & straightened your car back out for you.
It happens in a nano instant, most times before your tail even puckers up...lol Then your left asking "What just happened, I know I slid?"
Actually unless you know about having Yaw control on your vehicle many drivers may always wonder what angel was looking over them on that slick overpass that night? I'm sure there are many alive today simply left wondering exactly that?..lol
As I said it cant work on 2wd. Yaw can only work if it has AWD or 4wd as it brakes/speeds each wheel separately as needed to steer your car straight again. The steering itself is not actually overtaken so most never feel it much. Now newer electronic steering in cars may be that way today idk, but I really doubt it's changed? Mine is a 2007 non elect steering.
Yaw sensors are how airplanes fly during auto pilot so it's been safely used for yrs. I've never had any issues with the Yaw but people who lift 4wd's have had to reset the sensor at times. Very easy to do it yourself as the manual shows how.
I'd never go with 2wd again for the safety factor of it alone. Ive never replaced a wheel bearing on any Toy/Lex yet (owned 7) but I do have a front one going bad now but having 356k on my 4Runner with nothing but maintenance and normal wear items replaced so if that's changing them out a lot I can agree?..lol. Small price to pay for the life of your family anyway so I can accept it more often.
My thought is a vehicle like these.....go w/ awd.
i would tend to agree with this. My 07rx350 is awd. The only thing u may have to watch for with awd rxs is over time the transfer case seals can start to dry up and cause the transfer case to seep fluid. This is a issue currently on my rx. But i talked to one guy whos had a seeping transfer case for 10 years on his rx and hes just kept topping the fluid off every so often which is what i do at every oil change. i have the shop check and if needed top it off which they do for no charge for me.
any reason why you aren't considering the 350? The 330 engine uses a timing belt that usually needs replaced as soon as you buy it (a valid trade in reason on RX330s just passing the 100k mark)
the RX350 is the same car, just a newer version and the engine uses a timing chain.
FWIW I have an 08 RX350 FWD and it's quite bulletproof. I have owned 4x4 in the past... AWD is maybe unnecessary unless you have snow more than half the year.
I prefer FWD, Its lighter and less maintenance. I live in TN though.
The only bad thing is the tires do peel out in the rain.
Also most RXs sold in the south have FWD. A few AWD ones have migrated here over the years. And dealers sometimes keep a few new ones in their inventory for the people that just have to have it. Lexus of Memphis currently has 7 RXs in inventory only the hybrids are AWD.
