synthetic oil
Old 06-18-13, 11:10 AM
MDRX330
MDRX330's Avatar
Originally Posted by Carver
Another thing, if you have 38k undocumented miles I would seriously consider a complete fluid change.
Oil
Radiator
Brakes
Power steering
Transmission
Transfer case
etc,
Make sure the plugs were done and of course, the timing belt and water pump. You'll be ready for 300k!
Good point. Do you recommend a flush or is drain/removal sufficient? If dran/removal is ok, I'll do it on my own but if a flush where 100% of the old fluid needs to be removed i'll take it to a shop.
Old 06-18-13, 11:48 AM
Carver
Carver's Avatar
As you are probably aware, there aren't a lot of reported problems with these transmissions so apparently, they are bulletproof but clean fluid certainly won't hurt it. Personally, I would do a drain and refill.
If you are feeling especially generous and ambitious you might consider complete removal and replacement with Toyota WS fluid or a similar synthetic.
Old 06-18-13, 01:31 PM
MDRX330
MDRX330's Avatar
I'll go with a drain and do them more frequently with the fluids I can easily get to. Maybe every other oil change or so.
Old 06-18-13, 01:42 PM
mandyfig
mandyfig's Avatar
Been doing drain and fill on the tranny every 15 to 20K miles. Fresh fluid all the time. Pink and smells of no burnt oil!
jdavis500
GS F (2016-present)
14
08-25-23 07:10 AM
JASP615
GX - 1st Gen (2003-2009)
03-08-10 07:08 AM
sjgIS350
02-05-06 07:53 AM
noosense00
03-02-05 11:50 PM
martialart
Maintenance
21
10-30-03 06:47 PM
Quick Reply: synthetic oil
