Power Steering rack problem?
Old 08-27-13, 08:16 PM
compdr59
compdr59's Avatar
I checked the leak the Lexus dealer said I have. It turns out to be the boot over the inner tie rod is torn. Some grease leaked. Not power steering fluid. They say they don't fix these problems. They would be happy to sell the rack installed for $1500.
Old 08-28-13, 05:43 AM
RXPhil
RXPhil's Avatar
http://shop.rackdoctor.net/2007-2008...95-25963-2.htm
http://shop.rackdoctor.net/2004-2006...2995-25963.htm
Best price I could find. I have never used them before, but they seem alright. I emailed them once to ask questions and recieved a response promptly. Its nice to have a lifetime warranty.
Old 08-29-13, 03:35 AM
nwfsnake
nwfsnake's Avatar
Originally Posted by compdr59
I checked the leak the Lexus dealer said I have. It turns out to be the boot over the inner tie rod is torn. Some grade leaked. Not power steering fluid.
If your inner tie rod boot is torn, the only fluid that would leak at that point is power steering fluid, so I am not sure I understand???
Old 08-29-13, 08:09 PM
compdr59
compdr59's Avatar
The grease inside the boot leaks. I'm glad there's no red fluid coming out.
Old 09-22-13, 12:17 PM
mrmonster
mrmonster's Avatar
Great, my '07 has started to leak onto the ground.
Is there a DIY for this? I see one for SC ..wonder how close it would be.
Old 09-22-13, 01:31 PM
mrmonster
mrmonster's Avatar
Hmm I looked around under the car and both boots look clean. I don't see any leaks on the rack and pinion itself, I do see a very oily pipe that's very corroded.
This has to be it, my leak is massive and there was no signs of any drips before yesterday. I filled up the reservoir to the max yesterday and it's empty in less than 24 hours with the car just sitting.
Old 11-11-13, 02:24 AM
nwfsnake
nwfsnake's Avatar
Default Update on Rack Leak on our '07 RX350
Well, the boot on the right side started to disintegrate, so I ordered a replacement off of Amazon for $11. The leak itself is still very minor, so I removed the old boot, regreased the inner tie rod joint, and replaced the boot. Took less than an hour. Maybe it will last, maybe it won't. We have 103K on our '07 RX350, and I noticed the boot was damp (but not torn) right after we purchased it with 72K. I am still going to wait till the level in the ps reservoir starts to visibly drop before replacing. No problem with the left side yet, boot is in good shape and dry as a bone.
Old 12-25-13, 06:16 PM
nick62
nick62's Avatar
just joined this forum after searching steering rack failure ... mine just went out , although maybe shouldn't complain as I'm at 207,000 on my '04 330. I'd expect this on German cars but was hoping Japanese made would be more indestructible ...
what else should I expect to fail at this point? ABS warning light comes on intermittently as does the driver window control panel.
what is this vehicle worth even? do people buy cars with 200,000+ miles ?
Old 12-27-13, 01:23 AM
daryll40
daryll40's Avatar
Mine failed recently too at 61000 miles. Replaced under CPO warranty.
Old 12-28-13, 01:32 PM
felope100
felope100's Avatar
5 years ago Lexus told me my rack needed to be replaced because it was leaking.
i disregarded this warning and today im still driving with the same rack and there
is no issue. makes me wonder
Old 12-30-13, 06:19 AM
05RX330TX
05RX330TX's Avatar
Same here six months ago took my RX330 to Lexus dealer for power side mirror issue and been told my rack start to leak yesterday during changing my oil checking for the leak couldn't find any leak power steering fluid still as the same level six months ago. Still wonder here.
Old 12-31-13, 10:23 AM
house9999
house9999's Avatar
Bought 2007 Rx 350 at 58K under CPO warrenty
infamous engine check light and codes 2 times
annoying rack noise
some other minor troubles
Now.. shortly after CPO warrenty expired on March 2013..
Took car in for inspections and oil changes November 2013
told steering rack needs replaced for $1500
told engine cover needs replaced for $2000
Had catastrophic oil loss $400 rubber hose replaced
Known toyota /lexus issue
Old 12-31-13, 10:45 AM
RX330inFL
RX330inFL's Avatar
Engine cover??? Confused on this one.
OK, makes more sense here.
engine cover oil leak $2000 this just happend after warrenty expired
https://www.clublexus.com/forums/new...eply&p=8303917
Old 01-06-14, 09:39 AM
LiserAnn
LiserAnn's Avatar
Same thing here...took my '08 RX350 (approx 65K miles) in to Escondido Lexus for an oil change and was told the rack needed to be replaced...$1700!!! Say what?!?! I said, it only has 65K miles...seems to me this shouldn't need to be replaced so soon. The SA said that they consider it a wear and tear item. Needless to say I'll take it to an independent Lexus shop in town and have it done. It's rather discouraging to see how many people are having the same issue however.
Old 02-19-14, 10:10 AM
5mxe
5mxe's Avatar
In case you are looking for an independent shop in the San Diego area, The Truck Shop on Miramar Road is a good place for Lexus (and Toyota) work.
Quick Reply: Power Steering rack problem?
