Molding Strip for Roof
I have been trying (unsuccessfully) to locate the part number for the rubber molding strip that goes under the driver's side rail of the roof rack on my 2007 RX350. I tried Sewell's parst list and a couple of others with no luck.
Also, does anyone know if there are clips or does it just snap into place?
Thanks in advance!
Michael
Thanks in advance!
Michael
This should get you started. You will have to figure out which segments you are needing if you still have your roof rack installed. Believe these are glued into place if we are discussing the same part.
http://lexus.sewellparts.com/oem-cat...X350-2007.html
That 75556C is the long strip I was looking for. I'll contact Sewell to order it and ask if it should be glued.
