Timing Belt / Chain scheduled replacement on 08?
I see people discussing timing belt replacement on the RX as a scheduled item at 90K miles. I think that's only on older ones, right? I have a 2008 RX350 AWD and the only thing in the maintenance booklet is that the RX uses a timing chain (not a belt) and no inspection is required (presumably no scheduled replacement either).
Seems like that would be the most costly scheduled item as one gets into high mileage so I'm glad if I don't need it. I've done oil & filter replacements, brake pads, and air filters (engine and cabin) myself. Spark plugs I may have to get done if it requires significant disassembly just to get to.
I recently had the "pleasure" of the oil cooler tube failing. I took it to a Toyota dealer for that. Although it did not leave me literally stranded by the side of the road (I made it home adding oil a couple of times, then had it towed for service), it more or less did and that never happened with my last two vehicles, both driven into the 150-160K range. My Grand Cherokee had a myriad of small things wrong but still quite usable when I sold it. Before that, what I thought was a blown head gasket on my Honda Prelude turned out to be a tiny crack in the block. But it didn't leave me at the side of the road either. Whoda thunk it would happen with a Lexus?
Steve
Steve
The RX350 uses a timing chain and thus does not need replacement nor does it have any schedule for replacement.
The RX330 does have a timing belt. So, when we are talking about 2nd Generation RX needing to replace this part we are referring to 2004-2006 RX330.
The RX400h uses the same basic gas engine as the RX330, so it too has to have its timing belt replaced as needed.
2008, 350, belt, chain, lexus, ls460, maintenance, replacement, replacing, rx, rx350, schedule, timing, timing belt, timing chain
