RX 330 towing uhaul trailer cross country
Am looking at hauling a Uhaul 6X12 cargo trailer cross country to Northern California using our 2006 Lexus AWD RX330. The cargo trailer weighs 2000 lbs empty and will likely weigh about 3000 lbs loaded,
The car has done 60K miles has been well maintained. It does not have a factory installed trailer hitch.
Would it be advisable to attempt this road-trip and if so what precautions should I take with regard to properly equipping the vehicle to make the trip. Obviously a suitable trailer hitch will be installed but are there other steps I should take to ensure that we can make the trek safely without any major problems?
Renting a trailer one way would cost only $800 in comparison and we'd get better gas mileage with the RX330 pulling it.
Why do you advise against doing this with the RX330?
Just the pure distance & weight would scare me.
Instead of renting a truck, could you rent a car that could pull a trailer, have someone drive that, and someone else drive the RX?
I would just be afraid of burning out your tranny.
Posted from ClubLexus.com App for Android
While not officially stated in any RX literature I could find, if you look at similar Toyota products (such as the RAV4 and Highlander) with the same V6 engine and transmission installed you will note that their towing capacity is only 1500 or 2000 lbs without the Towing Package prep installed.
You can put in a new rebuilt tranny for 2500. at most shops. In my opinion it is worth the "risk". You need to drive it easy through the route and not mash the pedal down. Drive slow and easy and you will be fine. I towed a 2200 pound trailer across country in mine and did not have any lasting issues. I checked fluids often and took it easy.
Keep in mind, you are going to get close to 10 mpg towing with the RX.
If you do decide to embark on this journey with the RX, remember to put the shifter to "4" if the car starts hunting for gears/shifting back and forth.
Definitely make sure you have the tow prep package.
Remember you do not want to exceed the towing capacity. Not only because of mechanical stress, but due to legal issues. God forbid something happens, lawyers will have a play day knowing you were overweight.
If your trailer is already pushing 3,000 lbs. The combined weight of everything (occupants, RX itself, cargo, trailer) must be under 8745 lb.
From the manual:
From the manual:
The total trailer weight (trailer weight plus its cargo
load) must not exceed the following.
Exceeding this weight is dangerous.
Without towing package 907 kg (2000 lb.)
With towing package 1588 kg (3500 lb.)
If towing a trailer and cargo weighing over 907 kg
(2000 lb.), Lexus recommends to use a sway control
device with sufficient capacity.
The gross combination weight (sum of your vehicle weight plus
its load and the total trailer weight) must not exceed
the following.
Without towing package 3286 kg (7245 lb.)
With towing package 3966 kg (8745 lb.)
Trailer hitch assemblies have different weight
capacities established by the hitch manufacturer.
Even though the vehicle may be physically capable of
towing a higher weight, the operator must determine
the maximum weight rating of the particular hitch
assembly and never exceed the maximum weight
rating specified for the trailer hitch. Exceeding the
maximum weight rating set by the trailer hitch
manufacturer can cause an...
the following.
Thanks for all the responses.
Re renting a car to tow the trailer, rental companies will not allow their vehicles to be used for this purpose primarily because of liability issues. If there were to be an accident, I'd be personally liable.
I am glad I posed the question on this forum because I assumed that since the officially permitted weight is 3500 pounds, I would not have a problem staying well below that level.
I don't have the tow prep package on my car.
Yes, you are right about the Highlander having a 1500 pound limit. I wonder what the rationale is for the Lexus having a substantially higher limit given the similarity between the two vehicles.
How do you know you do not have the tow prep package? If you are assuming you do not because you don't have a hitch, then you are mistaken because the tow prep package did not come with a hitch (crazy but true).
Do you have a transmission cooler?
I assumed I did not because there is no hitch. How would I find out? Also, how would I know if I have a transmission cooler.
Sorry about the novice questions.
https://www.clublexus.com/forums/7652176-post12.html
