Steering wheel noise and hard
Old 06-12-13, 07:57 AM
hamedhg
hamedhg's Avatar
Question Steering wheel noise and hard
I have a 2005 RX 330, and have noticed that the steering wheel becomes very hard when turning either left or right. Also it makes some noise as well. The car has about 55k miles, and didn't expect this kind of problem, anyone else has had this problem?
Old 06-12-13, 08:11 AM
kiwi
kiwi's Avatar
a power steering rack leakage is common. and thus if yours is leaking, and low on fluid, you could have those problems.
start with checking your power steering fluid. its under the plastic piece on the passenger side under the hood. if you are low, dont add power steering fluid, these cars use transmission fluid instead.
if it is low, check either side of the car (under the engine area and look for leaks / the power steering boots moist / leaking.
hope that helps.
Old 06-12-13, 08:45 AM
Carver
Carver's Avatar
There was a problem with the steering column binding on some of the early 2 gen RX with symptoms that sound exactly like what you describe. Run a search on this forum for more info.
Old 06-12-13, 02:39 PM
hamedhg
hamedhg's Avatar
Default Thanks
Thanks all for the information, I will investigate further.
hg
watch37
Hybrid Technology
01-08-13 05:25 PM
aeroelasti
01-03-13 06:06 AM
Jfg kevin
Suspension and Brakes
15
12-19-09 12:20 PM
grace_gt
02-22-09 02:32 PM
Och
GS - 1st Gen (1993-1997)
07-31-03 09:23 PM
Quick Reply: Steering wheel noise and hard
