RX 330 aftermarket stereo install
Old 07-06-13, 02:17 PM
tipene
tipene's Avatar
Default RX 330 aftermarket stereo install
Hi fellow Lexus owners
A question regarding installing an after market stereo. Want to get the standard stereo out and have been quoted NZ $1500 by an installer which seems steep to me.
These guys are pros and have done good work for me before, but I am just hoping for some feedback
Heres the background
I have a 2010 Sony cd, radio , bluetooth etc, booster amp and grunty woofer that I own.
Installer said it needs the adapter face plate, a device to interface new gear with steering wheel, and some other parts to enable to after market system to work 100 % in the Lexus.
Reckons installing aftermarket stereos in to Lexus can be tricky
Yes I want it to work 100% but has anyone had this done previously and what sort of costs/advice do you have.
Thanks kindly in advance
Tip
Old 07-06-13, 04:17 PM
Carver
Carver's Avatar
https://www.clublexus.com/forums/sea...archid=2162441
Old 07-07-13, 01:22 PM
RX3302004
RX3302004's Avatar
I couldn't access a thread from this link.
Old 07-07-13, 04:02 PM
Rainbird
Rainbird's Avatar
Welcome to Club Lexus. We have a forum on CL called "Lexus Audio, Video, Security and Electronics. I did a search for RX330. Here is one of several you may find helpful.
https://www.clublexus.com/forums/lex...-04-rx330.html
Old 07-07-13, 04:39 PM
RX330inFL
RX330inFL's Avatar
No, not very tricky at all. Just need to have the right bits and pieces. You are looking for the Metra kit.
Spend some time here at CL using the search features and you will find a wealth of information on your task already existing.
Stressdawg (03-02-20)
Old 07-07-13, 05:08 PM
tipene
tipene's Avatar
Default thank you folks
Appreciate the friendly and helpful advice
Here is what they have said is required .NZ $
Does all this need to be done to install a good stereo supplied by myself??
Job description.
Install supplied Headunit, Amplifier, Subwoofer & Cables to connect amplifier.
Parts & Labour
1 x Lexus RX330 fitting kit $499
1 x Lexus Dash pocket $40
1 x Lexus side trim $25
1 x SWIX (Steering wheel control interface) $249
1 x Bose Interface (If required) $249
4 x Consumables $20
6 x install @ $69 total install cost of $414
Total cost of $1496 fully installed.
Will check your links and come back later ... thanks so much again
Old 07-07-13, 05:29 PM
RX330inFL
RX330inFL's Avatar
NZ$1496 = US$1,153.72 (approx. depending on exchange rate)
Because of the expense of shipping items to NZ, you will have to do your own research as to whether the Metra kit is available in your area, from whom and for how much. We do have a number of members here from Australia who might be able to chime in with suggestions.
Also, you did not state which stereo system you have in your RX and if you have NAV or not. Does come into play. You can go to the Metra web site to look at what is available for your configuration.
Old 07-08-13, 05:52 AM
mandyfig
mandyfig's Avatar
Do a research on crutchfielddotcom. Helpful. The n you can get your pieces right.
Old 07-09-13, 06:59 PM
tipene
tipene's Avatar
Default thanks mandy fig and lexus rx 330 infl
thanks for the steer on this
have been around a few more installers in NZ and it seems the old adage - "do it right do it once" applies.
FYI the gear I am supplying is
Stereo Sony MEX- BT5700u
Amp XM ZR 602
Woofer Soundstream Stealth 134 BX
Will let you know how it all goes....
cheers tip
Old 05-08-17, 06:07 PM
lexuswoo
lexuswoo's Avatar
Default climate control and new radio
Just put in a new alpine radio with bluetooth and usb. alpine 143cdbt.
Got the radio and all the necessary elecrtrical wiring harness adapters from crutchfiel. I highly recommend that you buy your stuff from crutchfield. great products and great support..
One big issue.. making the original climate control work.
My lexus is a 2005 with the nav screen and dvd entertainment screen.
I had a big problem with splicing in the small resistor. spent a bunch of time and phone calls to crutchfield.
This was the problem. even though i spliced in the resistor between the yellow and brown wires that are on the 12 pin connector coming from the cars wiring harness it did not
work at first. very frustrating.
So. we finally figured it out. I had to solder the resistor to the thin wires in order to get enough contact. .
Also.. NOTE. once the resistor is attached. you will leave the plug hanging . It does not need to be plugged into anything. Wierd ...but it works.
originally the plug went into the stock radio. but with a new radio there is no place to plug it into. Just solder the resistor and it will allow the
climate control to work.
I hope this helps folks out there.
the other metra adaptors are plug and play. steering wheel controls and the interface for the amplifier works seamlessly. no problems.
good luck
cost... 130 for radio 110 for all the wiring adapters. .
Old 05-09-17, 06:57 AM
mdbrown
mdbrown's Avatar
So where does the climate control information display?
Old 05-09-17, 07:06 PM
lexuswoo
lexuswoo's Avatar
it displays on the screen as normal when you push the climate button.
Old 05-11-17, 04:08 PM
Pepp
Pepp's Avatar
Smile Lexuswoo is correct
i purchased my stereo from Cruthfield as well. With the purchase they included all necessary hardware including face plate that looks like original equipment and small transistor needed for climate control, sterring wheel control plug,and detailed instructions on the removal and replacement with new receiver. I've taken mine out twice ( because I forgot to hook up my Bluetooth). It literally takes 5 minutes. Pry the bottom trim plate around the gear shifter with a small screw driver and then the little plate around the cigarette lighter. There are 4 10mm bolts holding the stereo in. As far as the little transistor goes there is an easy way to attach it. Instead of splicing into the 2 wires and soldering just insert the ends of the transistor into the two pins on the plug. Cruthfield gives the detailed instructions on which # wires and which pins they belong to. It turned out to be a simple install. I will attempt to attach the instruction sheet Crutchfield sent me but your better off just contacting them. If you are not familiar with then that are the best audio place to ever deal with as far as equipment,customer service,as well as the best technical support. You can literally do your own install for about $125. And it's very simple once you get started.just remember to disconnect your negative battery cable first. Also, when you reconnect your cable you have to reset your power windows for the auto go down from the driver side. Just go to each window put it down half way go up one inch and then back down all the way. Very simple. Any questions feel free to contact me pepemansion@msn.com
dan
Old 05-11-17, 06:33 PM
lexuswoo
lexuswoo's Avatar
Default Resustor
Great idea on the pin location for the vresister . Soldering was easy tjough since the plug diies not get plugged in. I cut the wires and soldered the resistor in line between the yelliw ans brown...no.9 and no.10.
Rudeboy88
ES - 5th Gen (2007-2012)
01-30-13 03:23 PM
Raposo927
02-07-12 03:58 AM
tq745
07-30-09 12:32 PM
rj4510
GX - 1st Gen (2003-2009)
09-27-06 07:31 PM
edgy
RX - 1st Gen (1999-2003)
09-18-06 01:02 PM
Quick Reply: RX 330 aftermarket stereo install
