Despritely Need Help (Canadian)
Hi all, I have 2007 RX350 and have blown an oil line. I am told the gaskets for the oil line are on back order across Canada and could take months. The oil is pissing out so the car is undrivable. ANY lead to get the following parts would be greatly appreciated.
gasket part # s 11496B and 15785
oil line # 15767
Thank You
brimcc@cogeco.ca
oil line # 15767
Thank You
brimcc@cogeco.ca
Search for this problem It may be the line itself and no just the gasket. If the line needs replacing but you cannot find a gasket, you can "re-use" the old one with some modification (you tube using old gasket or making a gasket.)
