Overall check, recommendations?
Hi Experts,
My RX330 has done about 55000 miles and have really been enjoying the drive till a few days back.
I was on my way back from Napa and for no apparent reason, I thought the car started swerving, afraid I had a flat, I pulled to the side and checked all four tires. There was nothing wrong with them, though there was a gust of wind blowing across the freeway (I-680) which seemed to be the culprit.
Got home safe and sound and then a few days back started feeling the same, could be psychological as well now. I checked the tread on all the tires which seems to be fine.
Am heading to COSTCO the coming weekend to get the tire rotation/balancing done. If I still feel the same, il head to a dealership to get the car inspected, what check would you recommend so that such (plus any other) issues can be detected?
Thanks !
/ Heeru
Thanks !
/ Heeru
Sounds like you may have busted a belt in one of your tires assuming the lug nuts are nice and tight.
https://www.clublexus.com/forums/gs-...tire-belt.html
busted belt usually happens at low speed, and will happen all the time.
you could rotate your tires front to back and see if it goes away. a broken belt on the back is harder to notice and wont affect steering
