Constant fuse
Hey all,
Does anyone know if theres a constant fuse in the fusebox under the driver's side panel? I am looking for a power source that remains on even if the car is off. Unfortunately I can't go check with a multimeter yet as I won't have access to the car till the weekend, but just doing some due diligence for a dash cam install ahead of time. Thanks in advance!
Hard to tell by heart, but I'm pretty sure that in the manual you can find the fuse layout, together with their amperage and the circuits connected (which in turn tells you which are always on and which aren't).
I would check that out anyway, because also the current required is worth considering, not just the fact that it's always on.
