Headlight restorer review (turtle wax kit)
This took about 20 minutes and was $7.99 at kmart (on sale, I think it's normall $9.99 most places). I have used just straight turtle wax and toothpaste on other cars, but I really enjoyed the ease of this kit.
The kit comes with a cleaner solution and 4 small 2" pads of different grit sand paper & a spray lubricant as well as a final cleanser wipe and a sealer wipe.
The only thing you'll need is a couple of cotton/terry cloths to apply and wipe off/buff and a little time.
You could probably get a little bit better of a response if you spent more time than I did, but I'm happy with the 20 minutes I spent to get this result.
enjoy.
2004 rx330
![Headlight restorer review (turtle wax kit)-tgrth15.jpg](https://www.clublexus.com/forums/attachments/rx-2nd-gen-2004-2009/499069d1683164836t-headlight-restorer-review-turtle-wax-kit-tgrth15.jpg)
enjoy.
2004 rx330
![Headlight restorer review (turtle wax kit)-nykmvyl.jpg](https://www.clublexus.com/forums/attachments/rx-2nd-gen-2004-2009/499070d1683164836t-headlight-restorer-review-turtle-wax-kit-nykmvyl.jpg)
I'm hoping it lasts too
The other way to do it is to pick up some 3M rubbing compound. It's pricy, at about $30 a quart, but it's the only thing that seems to give good long term results. A quart of rubbing compound will last you a long long time if you are only using it for headlights. Take some rubbing compound, and buff it in using a clean microfiber cloth. Once you get all the lights you are doing done, throw the rag away. Do not re-use this rag! Rubbing compound is an abrasive compound. It is normally used by body shops to remove fine clear coat scratches. Using it on plastic takes a fine layer off of it. Do not worry, the lens of your headlights is plenty thick. Rubbing compound takes off maybe a hair or two thick layer of plastic.
After using rubbing compound on your lights, I recommend following it up with a good wax to protect it from UV damage. As long as you keep a good layer of wax on it, your clear lights should stay clear for months.
For a permanent fix to yellowing lights, start with rubbing compound. If they are sufficiently clear, then clear coat the lights. If they aren't sufficiently clear, then wet sand the lights with an increasing grit (start with about 1600 or so) and then clear coat. Note: wet sanding can remove scratches and some minor pitting
The clear coating is best done by a local body shop. You want to use quality automotive clear coat, e.g. not spray can clear coat. Once clear coated, the clear lens should stay clear for years.
Also, it has a 24 hour cure time and I screwed mine up trying to wash the car/headlights too soon. I'm going to have to redo it :/
Tis is single-handedly the best detailed step-by-step on how to do this:
http://www.autopiaforums.com/forums/...storation.html
Bryan@Autogeek
Club Lexus Vendor Marketplace
15
02-03-14 08:43 AM
PFB
02-02-12 06:32 AM
LexLuger31
08-16-11 08:04 PM
