Rx 350 2007
Rx 350 2007
Hi: I have a RX 350 with GPS in dash
I have a question .
Why did the Maint. Req,d come on in the dash ?
I went to the display and everything checks out.
Is there a way to get this removed ?
Thanks Jerry
e-mail w0sat2@gmail.com
I have a question .
Thanks Jerry
Welcome to Club Lexus. Using the CL search you will see this has been discussed here many times. It will come on every 5,000 miles to remind you to service the vehicle. You can dismiss it by doing the following:
Make sure the odometer is set to total miles not trip. With the key in the off position, push in and hold the odometer button (ODO). Turn the key to the on position without starting the car. Continue to hold in the odometer reset button until the maintenance required light goes off (about 20 seconds).
