2004 RX330 Door Chimes When Turn or Over Bumps
I have a 2004 RX 330 - recently, when I turn corners, the interior chime goes off and dash light goes on with the alert that the rear door on the drivers side is open. Obviously the door is closed - and now its started the same dinging and light when I hit bumps in the road.
Has anyone else experienced this? Any solutions? Im thinking of just pulling the fuse... we have a tight budget & I cant afford to take it into the dealership...
hi
not sure if you've already resolved this. Could it be the door sensor on the rear door? Probably the one on the opposite side to the turning that causes the problem. I'm thinking you're turning right when problem happens?
The sensor switch is behind a rubber cover. Perhaps it's sticking slightly and you could remove it and clean it with one of those spray cleaners, reassemble, and try
cheers
cheers
JCIS250RWD
10-30-21 01:34 PM
Patrick92
02-25-15 08:06 PM
Gville350
10-10-11 11:20 AM
