Lexus Aftermarket Radio
All,
Got a 2009 RX350 and put a Pioneer head unit inside it with an amp and a set of shallow mount subs. Sounds good but noticed now that when I turn on the car, the system displays "Audio Off" and I cannot turn it back on. Is there anyone who has had this problem before? I took it back to the installer and he said that the car seems like its not recognizing the stereo and prhaps the newer head unit is sending les voltage per channel then the factory unit. Anyone got the specs for the factor head unit?
Like many questions you might have, this one has probably already been discussed previously here on CL. Did you take a look at this?
https://www.clublexus.com/forums/rx-...-question.html
Possibility that you either do not have the proper harness at all or the wrong one installed.
GATO
12-01-04 05:17 PM
