17" to 18" wheels
Been thinking of upgrading to some used Lexus 18" OE wheels for my '08 RX 350. Has anyone noticed a stiffer or more harsh ride switching from 17" to 18". Do you feel the imperfections in the road more ? Just wondering because when I switched my stock 16" wheels to Supra 17" on my '98 SC there was a difference, but not too bad.
____________________________________
2008 RX 350
1998 SC 300
2008 RX 350
1998 SC 300
Even with 18 inch rims, you still have plenty of sidewall. It may be just a tiny bit harsher, but I don't think you will notice. Like Rainbird mentioned, it seems that most RXs have the OEM 18s.
As neelnaik indicated, I think the 1/2-inch loss of sidewall is quite small compared to the remaining sidewall. Many coupes/sedans/wagons today can even accommodate 20-inch wheels without any adjustments to ride height. However, concerning the cars you quoted, I think there's an additional factor that the wheels that are considered good investments are products of better manufacture and materials; that means they would be a lot more homogenous on the molecular level than factory-standard wheels, so they're also more resonant to vibrations. Does this sound about right to all of you?
I had found a set of 4 2012 RX wheels and well used tires on ebay. I had read that the later year wheels weren't compatible with the '08's, offset or something else. I posted a question about fitment on here, but there was only a few hours left on the auction and they went for $236.00. So will all year OE Lexus RX wheels fit my '08 ? cause then I could go 19" or whatever. I really like the look of the 2012 RX 18" wheels. Yeah 18" OEM wheels are around $100-130 each
I follow what your saying hoOn.
Just my $0.02:
IMO Tire inflation pressure can play into harshness, too. I have formula for tire spring rate somewhere....You'd be surprised how stiff it can be. Start out with mfr's recommended pressures.
